Asus GeForce GT 730 902MHz 2GB PCI-E 2.0 HDMI LP w/ Bracket
£81.04
Delivery:
Standard: 1-3 working days
Key features
  • Dust-proof fan (25% longer graphics card lifespan)
  • Super alloy power (enhanced durability and cooling)
  • Stream online instantly
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GT 730, NVIDIA GeForce GT 730, NVIDIA GeForce GT 730
  • Interface: PCI Express 2.0 x16
  • Memory Size: 2GB, 2GB
  • Digital Output: Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Product codes
ASUS GT 730 delivers efficient multimedia and gaming performance
  • Dust-proof Fan design increases particle resistance and extends card lifespan by up to 25% longer than reference.
  • Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
  • Low profile graphics cards for HTPC and multimedia PCs support smooth 1280 x 1024 gaming and Blu-ray 3D. Brackets bundled for fast setup!
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played.
Product Description ASUS GT730-2GD5-BRK - graphics card - GF GT 730 - 2 GB
Device Type Graphics card - low profile
Bus Type PCI Express 2.0 x16
Graphics Engine NVIDIA GeForce GT 730
Memory 2 GB GDDR5
Core Clock 902 MHz
CUDA Cores 384
Effective Memory Clock 5.01 GHz
Memory Interface 64-bit
Max Resolution 2560 x 1600
Interfaces VGA , DVI-D , HDMI
API Supported DirectX 11
Dimensions (WxDxH) 2.65 cm x 14.5 cm x 6.9 cm
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus GeForce GT 730 90...
£81.04
