Asus GeForce GTX 690 915MHz 4GB PCI-Express 3.0 HDMI
Key features
  • NVIDIA GPU Boost
  • NVIDIA Adaptive V-Sync
  • SLI support
  • NVIDIA PhysX ready
  • NVIDIA 3D Vision Surround ready
  • 28 nm GPU
Product codes
The new ASUS Geforce® GTX690-4GD5 graphics card ships with Dual 28nm NVIDIA® GPU and 4GB GDDR5. To fully harness the power of dual-GPU technology, GTX690-4GD5 comes with ASUS exclusive GPU Tweak utility and NVIDIA® GPU Boost clock speed modulation that provides the fastest gaming performance. ASUS Geforce® GTX690-4GD5 offers gamers improved tuning access, and ultra-smooth gaming experience through NVIDIA® Adaptive VSync technology. It also supports NVIDIA® 3D Vision® surround™ on hundreds of PC games with a single card. Moreover, the card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0.
Selling Points
  • Dual 28nm GPU with 4GB GDDR5
  • NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels
  • NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
  • Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
  • PCI Express 3.0 Delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
  • Model GTX690-4GD5
  • Graphics Engine NVIDIA®GeForce®GTX 690
  • Bus Standard PCI Express® 3.0
  • OpenGL OpenGL®4.2
  • Video Memory 4096MBGDDR5
  • GPU boostClock 1019 MHz
  • GPU base Clock 915 MHz
  • CUDA cores 3072
  • Memory Clock 3004MHz(1502 MHz GDDR5)
  • Memory Interface 512bit
  • DVI Max. Resolution 2560 * 1600
  • DVI Output 3x NativeDual-link DVI
  • HDMI Output 1x Via DVI to HDMI Adapter
  • HDCP compliant YES
  • DisplayPort 1x NativeMini DisplayPort
  • Adapter/Cable Bundled 1x Power cable
  • Software Bundled ASUS GPU Tweak& Driver
  • Dimension The card size is 11x4.4x1.9inches
  • Note: The actual boost clock will vary depending on actual system conditions
Product Description ASUS GTX690-4GD5 - graphics card - GF GTX 690 - 4 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 690
Memory 4 GB GDDR5
Core Clock 915 MHz
CUDA Cores 3072
Effective Memory Clock 6.008 GHz
Memory Interface 512-bit
Max Resolution 2560 x 1600
Interfaces DVI-I (dual link) , DVI-D (dual link) , HDMI - with adapter , Mini DisplayPort
API Supported DirectX 11
Dimensions (WxDxH) 11.2 cm x 27.9 cm x 4.8 cm
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
