ASUS ROG MARS 760: Dual GPU. Ultimate Performance.
Exclusive DirectCU II technology puts 8 highly-conductive copper cooling pipes in direct contact with both GPUs. These achieve 20% cooler temps and vastly quieter than GTX 690.
Mars 760 packs ROG's acclaimed DIGI+ voltage-regulation module (VRM), with a 12-phase power design that reduces power noise by 30% and enhances efficiency by 15%. It also widens voltage-modulation tolerance and improves overall stability and longevity - by 2.5% times more than reference!
| Product Description | ASUS MARS760-4GD5 - graphics card - 2 GPUs - GF GTX 760 - 4 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | 2 GPUs - NVIDIA GeForce GTX 760 | Memory | 4 GB GDDR5 | Core Clock | 1006 MHz | Boost Clock | 1072 MHz | CUDA Cores | 2304 | Effective Memory Clock | 6.004 GHz | Memory Interface | 512-bit | Interfaces | 2 x DVI-I (dual link) , Mini DisplayPort , HDMI - with adapter , DVI-D (dual link) | Dimensions (WxDxH) | 4.06 cm x 27.9 cm x 11.1 cm | Microsoft Certification | Compatible with Windows 7 |
General | |
| CUDA Cores | 2304 |
| Features | Dual Fan Design, Super Alloy Power technology, ASUS DirectCU II Technology, Dust-proof fan, ASUS DIGI+ VRM, MARS LED light, HDCP |
Memory | |
| Size | 4 GB |
| Technology | GDDR5 SDRAM |
| Effective Clock Speed | 6.004 GHz |
| Bus Width | 512-bit |
Miscellaneous | |
| Cables Included | 1 x HDMI-DVI adapter |
| Software Included | Drivers & Utilities, ASUS GPU Tweak |
| Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
| Width | 4.06 cm |
| Depth | 27.9 cm |
| Height | 11.1 cm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
