Asus H110T Intel H110 S1151 DDR4 M.2 USB3.0 ThinMini-ITX
£88.14
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Advanced hardware safeguards
  • Overvoltage protection
  • Superb performance
  • Optimized cooling
  • Processor Socket: LGA1151 Socket
  • Chipset: Intel H110 Express
  • Graphics: Graphics adapter (CPU required)
  • Form Factor: Thin mini ITX
  • Memory Support: DDR4 SDRAM
Product codes
5X Protection II employs fine components and excellent circuit design to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build.
Product Description ASUS H110T - motherboard - Thin mini ITX - LGA1151 Socket - H110
Product Type Motherboard - Thin mini ITX
Chipset Type Intel H110 Express
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 32 GB
RAM Supported 2 SO-DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 2 x SATA-600, 1 x M.2
USB / FireWire Ports USB 3.0 4 x USB 3.0 + (5 x USB 2.0 via headers)
Max Allocated RAM Size 1024 MB
Audio HD Audio (8-channel)
LAN 2 x Gigabit Ethernet
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus H110T Intel H110...
£88.14
