Asus MB168B 15.6" 1366x768 11ms USB Powered LED Monitor
£138.24
Delivery:
Key features
  • 15.6-inch HD portable USB-powered monitor with a single USB 3.0 cable for power and data transmission
  • Slim and light USB monitor with a sleek and metallic finish
  • Diagonal Size: 15.6in
  • Max Resolution: 1366 x 768
  • Response Time: 11ms
  • Speakers: None
  • Interfaces: USB
Product codes
The 15.6-inch MB168B portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a 1366 x 768 HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality.
Product Description ASUS MB168B - LED monitor - 15.6"
Device Type LED-backlit LCD monitor - 15.6"
Panel Type TN
Aspect Ratio 16:9
Native Resolution 1366 x 768
Brightness 200 cd/m²
Contrast Ratio 500:1 (dynamic)
Response Time 11 ms
Input Connectors USB
Colour Black, silver
Dimensions (WxDxH) 37.9 cm x 0.8 cm x 23.6 cm
Weight 800 g
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MB168B 15.6" 1366...
£138.24
