Asus MB169B+ 15.6" LED-Lit Monitor IPS 1920 x 1080 USB...
Asus MB169B+ 15.6" LED-Lit Monitor  IPS  1920 x 1080 USB Powered
£198.26
Delivery:
Standard: 1-3 working days
Key features
  • 15.6-inch Full HD portable USB-powered monitor with a single USB 3.0 cable for power and data transmission
  • Slim and light USB monitor with a sleek and metallic finish
Product codes
Bundle deals (1)
TPLINK 25W 5-PORT USB CHARGER
Asus MB169B+ 15.6
Asus MB169B+ 15.6" LED-Lit Monitor IPS 1920 x 1080...
£198.26
= £211.26
Save £3.00
  • Sleek and ultra-portable with a Zen-inspired design
    With a slim 8 mm (0.3-inch) profile, the MB169B+ is slim and ligh companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations. A durable metallic finish with a fine pattern of concentric circles makes the MB169B+ the perfect complement to your notebook.
  • Adjusting to your needs
    The MB169B+ automatically senses its orientation and switches the display between landscape and portrait based on its position; also, featuring IPS panel ensures a better viewing angle and nearly no color shift promise. These features provide you a more user-friendly scenario.
  • Increased productivity with ASUS EzLink technology
    The MB169B+ features ASUS EzLink technology that offloads graphics processing from the PC to dedicated hardware in the monitor. As a result, a PC can drive up to five MB169B+ monitors at the same time, regardless of its own graphics capability - it just needs sufficient USB ports. EzLink also automatically restores application window positions as a MB169B+ monitor is connected and disconnected, and automatically rotates the image between landscape and portrait modes, as required.
The 15.6-inch MB169B+ portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a Full HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality.
ASUS MB169B+ - LED monitor - Full HD (1080p) - 15.6"
LED-backlit LCD monitor - 15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.179 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 (dynamic)
Response Time
25 ms
Input Connectors
USB
Black, silver
37.9 cm x 0.85 cm x 23.6 cm
800 g
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MB169B+ 15.6" LED...
£198.26
