Asus MB169C+ 15.6" Full HD USB-TypeC Portable USB Monitor
£212.24
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 15.6in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: USB
Product codes
The MB169C+ is a 15.6-inch portable companion monitor that uses a single USB Type-C connection for both power and video transmission. It is a wide QHD monitor with a 2000R curvature. MB169C+ has a Full HD IPS panel that delivers stunning resolution visuals with an advanced color reproduction, as well as wide viewing angles for minimal color shift even when viewed from extreme positions.
Product Description ASUS MB169C+ - LED monitor - Full HD (1080p) - 15.6"
Device Type LED-backlit LCD monitor - 15.6"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.179 mm
Brightness 220 cd/m²
Contrast Ratio 700:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Input Connectors USB
Colour Black, silver
Dimensions (WxDxH) 37.9 cm x 0.85 cm x 23.6 cm
Weight 800 g
Compliant Standards UL, TUV, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, UkrSEPRO, RCM, TUV Rheinland Low Blue Light Certification, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MB169C+ 15.6" Ful...
£212.24
