Asus MG279Q 27" 2560x1440 4ms (GTG) WQHD IPS 144Hz Gamin...
Asus MG279Q 27" 2560x1440 4ms (GTG) WQHD IPS 144Hz Gaming Monitor
144HZ REFRESH RATE AND AMD FREESYNC™ TECHNOLOGY
£493.05
19 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, Mini DisplayPort, Mobile High-Definition Link (MHL)
Product codes
A Universe of Gaming at Your Command
  • 27-inch, WQHD 2560 x 1440 resolution display with IPS technology provide wide-viewing angles, and clear, vivid visuals
  • 144Hz refresh rate and AMD FreeSync™ technology for seamless visuals and smooth gameplay
  • ASUS-exclusive Ultra-Low Blue Light, Flicker-Free, GamePlus, and GameVisual technologies provide a comfortable gaming experience
  • Ergonomically-designed stand with full tilt, swivel, pivot, and height adjustment for comfortable viewing position
This is a sleek 27-inch display with in-plane switching (IPS) technology and WQHD 2560 x 1440-pixel resolution. MG279Q offers frame rates of over 120fps (120Hz), and with a 4ms grey-to-grey (GTG) response time it delivers ultra-smooth performance for true-to-life gaming experiences.
MG279Q has a gamer-friendly design, with an exclusive five-way navigation joystick for quick navigation of the intuitive on-screen display (OSD) and a dedicated GamePlus hotkey, which displays a customizable crosshair and timer overlap for enhanced combat. The display's super-narrow bezel means that MG279Q blends beautifully into any setting, while the ergonomic design allows full tilt, swivel, pivot and height adjustment. MG279Q also has a smart cable-management system built in and it's VESA wall-mountable.
Connections include DisplayPort, Mini DisplayPort, two HDMI ports (for native WQHD) and a Mobile High-Definition Link (MHL) 2.0 socket for 1080p connections to mobile devices, plus simultaneous charging. MG279Q also has a built-in dual USB 3.0 hub for device changing and data transfers that are up to ten times (10X) faster than USB 2.0.
Product Description ASUS MG279Q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 58 kWh
Power Consumption (On mode) 40 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 144 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 62.5 cm x 23.8 cm x 55.9 cm
Weight 7.3 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, J-MOSS, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MG279Q 27" 2560x1...
£493.05
