Asus MG28UQ 28" 3840x2160 1m 4K HDMI LED Monitor
£416.66
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Highly detailed visuals
  • Lightning-fast response time
  • Robust connectivity
  • Ergonomic design
  • Diagonal Size: 28in
  • Max Resolution: 3840 x 2160
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Gaming at Your Command
  • 28-inch 4K UHD (3840 x 2160) monitor for stunning photo-realistic visuals.
  • Lightning-fast 1ms rapid response time and Adaptive-Sync technology for incredibly-smooth and fast gaming visuals.
  • DisplayPort 1.2, HDMI(v 2.0) for 4K UHD playback; two USB 3.0 ports for quick-charging to your mobile devices.
  • ASUS-exclusive Ultra-Low Blue Light, Flicker-Free, GamePlus, and GameVisual technologies provide tactical assistance on your command.
A 28-inch 4K UHD display for highly-detailed visuals and more onscreen space
With its 28-inch 4K UHD display, ASUS MG28UQ gives you stunning 3840 x 2160 resolution visuals with a pixel density of 157PPI for incredible photo-realistic visuals and sharp, crisp text. The MG28UQ gives you four times the pixels of similar-sized Full HD 1080p displays so you get more detailed images when playing games or watching movies, as well as more onscreen desktop space for your various work windows. MG28UQ draws you into immersive virtual worlds, with greatly-textured elements and terrain maps that boast impressive levels of detail.
Even with today's fastest games, ASUS MG28UQ eliminates smearing and motion blur thanks to a 1ms response time – the fastest in its class. This astonishing visual performance lets you react instinctively to what you see onscreen, so you can take corners like a pro race car driver, or take an enemy out with a headshot as he peeks around cover. In addition, Adaptive-Sync technology eliminates screen tearing and choppy frame rates for even more seamlessly smooth gameplay.
Robust connectivity
Whether you're playing games or streaming videos, ASUS MG28UQ gives you smooth 4K UHD content playback, thanks to a 60Hz refresh rate and native 4K UHD support via DisplayPort 1.2, HDMI(v 2.0). In addition to its array of connectivity options, the MG28UQ even features two USB 3.0 port that lets you quick-charge your mobile devices while gaming;. Command, control, and charge your phone with a double USB 3.0 array, perfect for your keyboard and mouse of choice.
ASUS-exclusive GamePlus technology
ASUS MG28UQ features the ASUS-exclusive GamePlus hotkey to give you in-game enhancements that help you get more out of your game.
Crosshair
You can choose between four persistent crosshairs and fine tune their position, ensuring pinpoint accuracy in first-person shooters. Enjoy perfect aim even when the game doesn't provide its own crosshair or sights.
ASUS-exclusive GameVisual technology
ASUS GameVisual Technology gives you six preset display modes tailored to suit different types of scenarios. This unique feature can be easily accessed through a hotkey or the On Screen Display (OSD) settings menu.
Ultra-Low Blue Light technology
ASUS Ultra-Low Blue Light technology reduces the amount of harmful blue light emitted by ASUS MG28UQ. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand.
Low Blue Light Level
The MG28UQ gaming monitor has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
Flicker-Free technology
Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Ergonomic design
ASUS MG28UQ is specially designed for long marathon gaming sessions. Its ergonomically-designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position. A quick-release latch lets you separate the MG28UQ from its stand so you can mount it on a wall.
Product Description ASUS MG28UQ - LED monitor - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 62 kWh
Power Consumption (On mode) 42 W
Adaptive-Sync Technology VESA Adaptive-Sync
Features 5-way joystick, USB 3.0 hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 60 Hz, HDMI2-3: 30 Hz)
Pixel Pitch 0.16 mm
Brightness 330 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Input Connectors 3xHDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 66.026 cm x 23.34 cm x 56.6 cm
Weight 8 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, PSE Mark, MEPS, J-MOSS, UkrSEPRO, ERP, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Accessories
Accessories
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MG28UQ 28" 3840x2...
£416.66
