Asus Mini PC PB40 BC154ZD Intel Celeron N4100 4GB 64GB Window...
Asus Mini PC PB40 BC154ZD Intel Celeron N4100 4GB 64GB Windows 10 Professional 64-bit
£267.08
Delivery:
Standard: 1-3 working days
Key features
  • Ultraslim chassis: versatile desktop PC in a slimline, one-liter metal case
  • Comprehensive connectivity: flexible I/O for a wide range of uses
  • 24/7 reliability: extensively tested to ensure long-term reliability
  • Processor Type: Celeron
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 4GB
  • Hard Drive Capacity: 64GB
  • Storage Type: SSD
Product codes
ASUS Mini PC PB40 packs versatile desktop-computing power into stylish metal case that's just 17.5cm square, and a mere 3.4cm slim. Inside compact chassis is the latest Intel® Celeron® processor, with optional fanless(1) design for operation that's totally silent. The one-liter volume is no barrier to connectivity, with built-in Wi-Fi and USB 3.1 Gen 1 Type-C™ for simple, quick data transfers. Mini PC PB40 even has a flexible I/O port(2), so you're free to choose a DisplayPort, VGA or COM socket to best fit the needs of your business.
(1)Fanless design is only available on select models
(2)Flexible I/O ports availability may vary by model or region
Product Description ASUS Mini PC PB40 BC154ZD - mini PC - Celeron N4100 - 4 GB - 64 GB
Type Personal computer - mini PC
Processor Intel Celeron N4100 (Quad-Core)
RAM 4 GB (installed) / 8 GB (max) DDR4 SDRAM
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 64 GB - eMMC
Optical Storage No optical drive
Graphics Controller Intel UHD Graphics 600
Networking GigE, 802.11ac, Bluetooth 5.0
OS Provided Windows 10 Pro 64-bit Edition
Colour Black
Dimensions (WxDxH) 17.5 cm x 17.5 cm x 3.42 cm
Weight 700 g
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus Mini PC PB40 BC15...
£267.08
