Asus MX279H 27" LED IPS Monitor 1920x1080 VGA Dual HDMI
BEAUTY BEYOND BOUNDARIES FULL HD IPS LED-BACKLIT & FRAMELESS MONITOR
Key features
  • Incredibly subtle but sophisticated
  • The IPS technology with 178° wide-view angles
  • Built tough and gamer-centric comfortable
  • ASUS smart contrast ratio for lifelike visuals
  • QuickFit virtual scale for true what you see is what you get
  • Premium immersive audio
  • Greater and smoother output with bigger speakers
  • Audio by Bang & Olufsen ICEpower
  • Dual HDMI for extensive connectivity
Product codes
Beauty Beyond Boundaries: Full HD AH-IPS LED-backlit and Frameless Monitor
  • Full HD AH-IPS LED display with 178° wide-view angle in frameless design for edge-to-edge brilliance
  • ASUS SonicMaster Technology, co-developed with Bang & Olufsen ICEpower® for premium immersive audio
  • Featuring dual HDMI ports for multi device connections
  • Good Design Award Winner for its ultra-slim, ergonomic design with sturdy sundial-inspired stand
Inspired by millennia of artistic legacy, the Designo MX series sports an elegant and precision-crafted sundial design. The MX279H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ technology for incredible visuals. In addition, built-in ASUS SonicMaster technology, co-developed with Bang & Olufsen ICEpower, delivers immersive premium audio performance.
Designo MX279H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology - delivering improved color accuracy plus increased energy efficiency.
The Designo MX279H features ASUS SonicMaster technology - which was co-developed by the ASUS Golden Ear team and Bang & Olufsen ICEpower. This ASUS-exclusive audio technology combines advanced hardware and software to refine every acoustic detail in pristine quality to deliver crystal clear, true-to-life surround sound - reproducing richer and more distinct vocals at a wider frequency range and louder volumes.
Product Description ASUS MX279H - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 33.7 kWh
Power Consumption (On mode) 23.1 W
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Brightness 250 cd/m²
Contrast Ratio 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black, silver
Dimensions (WxDxH) - with stand 62.26 cm x 22.52 cm x 44.13 cm
Weight 5.2 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, GOST-R, J-MOSS, ErP Ready
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MX279H 27" LED IP...
