Asus MX34VQ 34" Curved 3440 x 1440 4ms HDMI Monitor
£676.39
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Large display with 178┬░ wide-view angle in frameless design for edge-to-edge brilliance
  • Powerful stereo speakers featured with Harman Kardon audio and ASUS SonicMaster technologies
  • Featuring HDMI and DP ports for multi device connections
  • Qi Wireless Charger designed in the base with Aurora lighting on while charging Qi-enabled devices
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Inspired elegance. Immersive experience.
Perfectly curved for immersive visuals
Take home entertainment to the next level with the ASUS Designo MX34VQ curved display. The 34-inch, ultra-wide QHD Designo monitor has a 21:9 aspect ratio and a 1800R curved screen for a wider field of view. The Designo MX34VQ features 178┬░wide-view technology across its horizontal and vertical planes, allowing you to enjoy beautiful visuals from almost any angle.
Ultra-wide QHD for incredibly detailed images
The ultra-wide QHD of the Designo display features 2.5x the resolution of a Full HD display, so it provides 35% more onscreen space than other Full HD displays of a similar size. The extra resolution makes multitasking more enjoyable and more efficient.
High contrast ratio for vibrant colors
The ultra-high 3000:1 contrast ratio of the Designo produces the brightest whites and the darkest black hues, delivering exceptionally distinct imagery.
Built-in Qi wireless charger
Messy wiring and misplaced chargers are a thing of the past with the Designo MX34VQ. Its transparent base has a built-in Qi wireless charger that automatically charges Qi-compatible devices the moment they are placed on the base. The base has built-in LEDs and emits an aurora-like glow during charging.
Product Description ASUS MX34VQ - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class C
Energy Consumption per Year 108 kWh
Power Consumption (On mode) 74 W
Curved Screen Yes
Panel Type VA
Aspect Ratio 21:9
Native Resolution UWQHD 3440 x 1440 at 100 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 3xHDMI, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Dark grey, plasma cooper
Dimensions (WxDxH) - with stand 81.06 cm x 45.68 cm x 23.97 cm
Weight 8.4 kg
Compliant Standards UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, J-MOSS, ERP, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus MX34VQ 34" Curved...
£676.39
