Asus N3050I-C mini ITX Intel Celeron N3050 USB 3.0 Gigabit LAN
Key features
  • Strict compatibility and validation
  • LANGuard for advanced LAN protection
  • Enhanced DRAM overcurrent protection
  • 5K-hr solid-state capacitors that last 2.5x longer
  • Stainless-steel back I/O that lasts 3x longer
  • ESD Guards for protection from electrostatic discharge
  • Proven compatibility
  • Designed - great compatibility with ASUS products
  • 170% faster transfer speeds with USB 3.0 Boost
Product codes
They are the world's biggest motherboard manufacturer, and renowned the design thinking that revolves around users - just like you. The engineers employ exacting standards to guarantee quality throughout the product's life, choosing the finest components for real-world protection. The motherboards are proven to be compatible with more than 1,000 components and devices, and undergo a minimum of 7,000 hours of strict validation. That gives you the peace of mind of knowing that ASUS motherboards are fit for all environments and applications. To build your PC with the best foundations, build it with an ASUS motherboard.
ASUS LANGuard socket has advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity.
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected device.
ASUS N3050I-C - motherboard - mini ITX - Intel Celeron N3050
Motherboard - mini ITX
Intel Celeron N3050 (Dual-Core)
Max RAM Size
8 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600
USB / FireWire Ports
USB 3.0 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
Intel HD Graphics
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus N3050I-C mini ITX...
