Asus N3150I-C mini ITX Intel Celeron N3150 USB 3.0 Gigabit LAN
Key features
  • Hardware safeguards to ensure long-term durability
  • LANGuard for advanced LAN protection
  • Enhanced DRAM overcurrent protection
  • 5K-hr solid-state capacitors that last 2.5x longer
  • Stainless-steel back I/O that lasts 3x longer
  • ESD Guards for protection from electrostatic discharge
Product codes
Great ethos underscores the choice of every single component that goes into your ASUS motherboard which ensuree long-term system reliability and performance. ASUS LANGuard socket has advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity. Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected device.
ASUS N3150I-C - motherboard - mini ITX - Intel Celeron N3150
Motherboard - mini ITX
Intel Celeron N3150 (Quad-Core)
Max RAM Size
8 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600
USB / FireWire Ports
USB 3.0 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
Intel HD Graphics
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus N3150I-C mini ITX...
