Asus NVIDIA GeForce GTX 1050 2GB GDDR5 PCIe3.0 Graphics Card
Key features
  • Your compact build
  • Dual-ball bearing fan
  • Auto-Extreme technology with Super Alloy Power II
  • GPU Tweak II with XSplit Gamecaster
  • XSplit Gamecaster - stream and record your gameplay instantly
Product codes
ASUS Phoenix GeForce GTX 1050 comes equipped with a dual ball-bearing fan for a 2X longer card lifespan and exclusive Auto-Extreme technology with Super Alloy Power II components for superior stability. ASUS Phoenix GeForce GTX 1050 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and real-time streaming.
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Phoenix GeForce GTX 1050 lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
Product Description ASUS PH-GTX1050-2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1050
Memory 2 GB GDDR5
Core Clock 1354 MHz
Boost Clock 1455 MHz
CUDA Cores 640
Effective Memory Clock 7.008 GHz
Memory Interface 128-bit
Max Resolution 7680 x 4320
Interfaces DVI-D (dual link) , HDMI , DisplayPort
API Supported OpenGL 4.5
Dimensions (WxDxH) 3.7 cm x 19.2 cm x 11.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
