Asus P8P67-M PRO REV 3.0 LGA1155 Intel P67 DDR3 mATX (B3 Step...
Asus P8P67-M PRO REV 3.0 LGA1155 Intel P67 DDR3 mATX (B3 Stepping)
Key features
  • Quad-GPU SLI and quad-GPU CrossFireX support
  • TPU
  • EPU
  • AI Suite II
  • Auto tuning
  • TurboV
  • MemOK!
  • Anti-surge protection
  • 100% all high-quality conductive polymer capacitors
  • Fanless design: stylish heatsink solution
  • Fan Xpert
  • True Serial ATA 6Gbps support
  • USB 3.0 support
  • S/PDIF out connector at the back I/O
  • 8-channel high definition audio
  • EFI BIOS (EZ mode)
Product codes
P8P67-M PRO - Dual Intelligent Processors - TPU & EPU for Overclocking & Energy Savings
  • ASUS TPU - The Ultimate Turbo Processor
  • ASUS EPU - Energy Efficiency All Around
  • EFI BIOS (EZ Mode) - Flexible & Easy BIOS Interface
  • Quad-GPU CrossFireX Support / SLI Support
  • USB3.0/SATA 6Gb/s Support - Double Access, Double Convenience
LGA1155 socket for Intel® Second Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
This motherboard supports the Intel® second generation Core™ i7 / Core™ i5 / Core™ i3 processors in LGA1155 package with memory and PCI Express controllers integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes. This provides great graphics performance. Intel® second generation Core™ i7 / Core™ i5 / Core™ i3 processors are among the most powerful and energy efficient CPUs in the world.
Intel® P67 Express Chipset
The Intel® P67 Express Chipset is the latest single-chipset designto support the new 1155 socket Intel® Core™ i7 / Core™ i5 / Core™ i3 second generation processors. It uses serial point-to-point links, which allows increased bandwidth and stability, and provides an improved performance. It also provides two SATA 6.0 Gb/s and four SATA 3.0 Gb/s ports for faster data retrieval at double the bandwidth of current bus systems.
Dual-Channel DDR3 2200(O.C.) / 2133(O.C.) / 1866(O.C.) / 1600(O.C.) / 1333 / 1066MHz support
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.) / 2133(O.C.) / 1866(O.C.) / 1600(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
Quad-GPU SLI and Quad-GPU CrossFireX Support!
Flexible Multi-GPU solutions, Your Weapon of Choice! P8P67-M PRO brings multi-GPU configurations through both SLI™ and CrossFireX. This motherboard features the powerful Intel® P67 platform, optimizing PCIe allocation in multiple GPU setups. Expect a brand new gaming sensation like you've never experienced before!
TPU
Unleash your performance with ASUS' simple onboard switch or AI Suite II utility. ASUS Auto tuning feature can intelligently optimize the system for fast, yet stable clock speeds, and the TurboV gives you the freedom to adjust CPU frequencies and ratios to optimize performance under varied system conditions.
EPU
Tap into the world's first real time PC power saving engine through a simple onboard switch or AI Suite II utility. Get total system power savings by automatically detecting current PC loadings and intelligently moderating power consumption. This also reduces fan noise and extends component longevity.
True Serial ATA 6Gb/s support
The Intel® P67 Express Chipset natively supports the Serial ATA (SATA) interface, delivering up to 6.0 Gb/s data transfer. ASUS provides extra SATA 6.0 Gb/s ports with enhanced scalability, faster data retrieval, and double the bandwidth of current bus systems.
USB 3.0 support
Experience ultra-fast data transfer at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10 times faster and is also backward compatible with USB 2.0 components.
EFI BIOS (EZ Mode)
Flexible & Easy BIOS Interface. The new ASUS EFI BIOS is an Extensible Firmware Interface that complies with uEFI architecture, offering a user-friendly interface that goes beyond traditional keyboard-only BIOS controls to enable more flexible and convenient mouse input. Users can easily navigate the new EFI BIOS with the same smoothness as their operating system. The exclusive EZ Mode displays frequently-accessed setup info, while the Advanced Mode is for experienced performance enthusiasts that demand far more intricate system settings.
Product Description ASUS P8P67-M PRO - 3.0 B3 - motherboard - micro ATX - LGA1155 Socket - P67
Product Type Motherboard - micro ATX
Chipset Type Intel P67 Express
Processor Socket 1 x LGA1155 Socket
Max RAM Size 32 GB
RAM Supported 4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports 2 x SATA-600 (RAID), 1 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-600
USB / FireWire Ports USB 3.0, FireWire 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 + (1 x FireWire + 8 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Asus P8P67-M PRO REV 3...
