ASUS PA238Q - LCD display - TFT - LED backlight - 23" -...
ASUS PA238Q - LCD display - TFT - LED backlight - 23" - widescreen, HDMI, DVI-D, VGA, - black
Key features
  • Ultimate color precision
  • User-friendly solutions
  • Hassle-free connection
  • Mercury-free LED-backlit panel
Product codes
The Professional Monitor with a Touch of Play
  • IPS panel with 100% sRGB coverage and 178 wide viewing angle
  • Every unit is factory-calibrated for superior color fidelity
  • QuickFit Virtual Scale instantly boosts design efficiency by providing real-size document, photo and grid on screen
Ultimate Color Precision
High Color Accuracy with Low Delta E
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity.
178° Wide Viewing Angle
PA238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
Flawless Gradation with 10-bit Look-up Table
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution
User-friendly Solutions
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Supporting Formats:
  • Document: A4, letter
  • Photo: 8"x10", 5"x7", 4"x6", 3"x5", 2"x2"
  • Grid: Alignment, Centimeters, Inches
Versatile Comfort with Ergonomic Design
The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position
Customized Color Adjustment
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors
Picture-in-Picture and Picture-by-Picture
Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want
Hassle-Free Connection
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc
Embedded LED backlight panel helps power saving and environmental protection with no mercury usage
ASUS PA238Q - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
54.9 cm x 20.1 cm x 49.6 cm
5.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, RoHS, ISO 9241-307, WEEE, GOST-R, J-MOSS, ErP Ready, TCO Displays 5.2
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
ASUS PA238Q - LCD disp...
