Asus PA279Q 27" 2560x1440 6ms DVI-D HDMI DisplayPort LED...
Asus PA279Q 27" 2560x1440 6ms DVI-D HDMI DisplayPort LED Monitor
Key features
  • Color consistency for photographer and retouching with 99% Adobe RGB color space
  • 10-bit color for smoother gradations
  • Pre-calibrated right out-of-the box
  • Next-generation IPS display technology
  • See better and wider
  • Made for work and play
  • 6-axis independent color adjustment
  • Uniformity compensation
  • Robust connectivity
  • Splendid video intelligence technology
  • Intuitive 5 way navigation key
  • Customizable OSD shortcuts
  • Picture-in-Picture and Picture-by-Picture
  • QuickFit virtual scale function
  • Ergonomic design
Product codes
The ASUS PA279Q is pre-calibrated at the factory for the highest accuracy and outstanding color space reproduction - 99% Adobe RGB, 100% sRGB, and 120% NTSC. With a wide color gamut of 99% Adobe RGB, the colors seen in photos will be reproduced faithfully and consistently in a way that cannot otherwise be on monitors with just an sRGB color space.
The PA279Q offers 10-bit display color for over one billion onscreen colors and support 14 bit internal lookup table (LUT), which gives smoother gradations and a more natural transition between hues.
The out-of-box settings are impressive as each PA279Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA279Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling.
It even supports Gamma 2.2 for PC and Gamma 1.8 for Mac - offering users more flexibilities to work with. Each PA279Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color difference to ?E (Delta E) of less than 2 - ensuring precise reading of color input and guarantees excellent color fidelity.
ASUS PA279Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
63.7 kWh
Power Consumption (On mode)
43.6 W
5-way navigation button, USB Hub, 9-in-1 card reader
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Speakers
Integrated
Display Position Adjustments
64.078 cm x 24 cm x 55.984 cm
10 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, WEEE, PSE Mark, J-MOSS, UkrSEPRO, ERP, CEL, TCO Displays 6.0
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PA279Q 27" 2560x1...
