Asus PA329Q 32" 3480x2160 HDMI LED Monitor
Key features
  • 360-degree rotation
  • Wide color gamut for vibrant images
  • High color fidelity for truly expressive hues
  • Color accuracy optimization
  • Enjoy stunning photos and videos in 4K UHD
  • QuickFit Virtual Scale
Product codes
The ASUS ProArt PA329Q 4K UHD professional monitor delivers accurate and brilliant color reproduction and is designed for graphics professionals. PA329Q is ideal for high-end video editing, thanks to a wide color gamut of 100% Rec. 709 and 99.5% Adobe RGB for exceptional color fidelity, and it has the ability to display multiple 4K UHD video inputs at up to 60Hz. In addition, ASUS ProArt Calibration Technology offers advanced color tuning and uniformity compensation to ensure outstanding color accuracy, making PA329 the perfect monitor for photographers, colorists, graphic designers, and film editors.
ProArt PA329Q has a wide color gamut so you have an entire spectrum of colors to play with. The use of 3M Quantum Dot Enhancement Film (QDEF) provides a wide color range, allowing PA329Q to support 100% Rec. 709, 100% sRGB, 99.5% Adobe RGB, 90% DCI-P3, and Rec. 2020 color spaces for video editing and production. On top of that, IPS display technology gives you wide viewing angles so there's no color shift, even when you're viewing PA329Q from extreme positions.
Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each ProArt PA329Q monitor is factory pre-calibrated to guarantee industry-leading color accuracy (?E < 2), so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. PA329Q also comes with 95% uniformity compensation to guard against brightness and chroma (color) fluctuations on different parts of the screen.
Product Description ASUS PA329Q - LED monitor - 4K - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 67 kWh
Power Consumption (On mode) 46 W
Features 9-in-1 card reader, USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch 0.1845 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Input Connectors 4xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 73.5 cm x 24 cm x 61.5 cm
Weight 12.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
