We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
ProArt PA32UC brings onscreen realism to another level. Its Ultra HD Premium-certified 4K IPS panel produces up to 1000 nits of brightness and delivers Rec. 2020, Adobe RGB, DCI-P3 and sRGB color space, providing a lifelike HDR experience that is ideal for advanced video editing. ProArt PA32UC is factory pre-calibrated and it features ProArt calibration technology to ensure color accuracy with a ?E value below 2. Certified for Windows and Mac OS, it's ideal for graphic designers, photographers and professional content creators.
Product Description | ASUS ProArt PA32UC-K - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class B | Energy Consumption per Year | 67 kWh | Power Consumption (On mode) | 46 W | Features | 5-way joystick, USB 3.0/USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 65 Hz, Thunderbolt 3: 60 Hz) | Pixel Pitch | 0.1845 mm | Brightness | 1000 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 100% sRGB, 85% Rec 2020, 95% DCI-P3 | Input Connectors | 4xHDMI, DisplayPort, Thunderbolt 3 | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Grey | Dimensions (WxDxH) - with stand | 72.7 cm x 22.9 cm x 60 cm | Weight | 11.4 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Built-in Devices | USB 3.0/USB-C hub |
Panel Type | IPS |
Vertical Refresh Rate | 29 - 65 Hz |
Horizontal Refresh Rate | 109 - 142 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, picture by picture, ErgoDesign, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, 14-bit lookup table, Flicker Free technology, ASUS EyeCare Technology, 6-axis colour adjustment, ASUS ProArt Calibration technology, Bluelight Filter, Hardware Calibration Ready, USB-C power delivery up to 60 W |
Colour | Grey |
Dimensions (WxDxH) | 72.7 cm x 22.9 cm x 60 cm - with stand |
Weight | 11.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | Thunderbolt 3 / USB-C , Thunderbolt 3 / USB-C output , 4 x HDMI , DisplayPort , Headphones , USB 3.0 downstream with Power Delivery , 2 x USB 3.0 downstream , USB 3.0 upstream |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 120 |
Rotation Angle | 180 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x Thunderbolt 3 / USB-C cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 56.84 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 72.7 cm - depth: 6.9 cm - height: 42.6 cm - weight: 7.8 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 91.3 cm |
Shipping Depth | 52.1 cm |
Shipping Height | 36.5 cm |
Shipping Weight | 16.7 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
