Asus PB277Q 27" 2560x1440 1MS HDMI, DVI-D VGA Monitor
£277.77
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Impeccable lifelike visuals with 27" 16:9 2560 x 1440 75 Hz with 1 ms fast response time
  • Extensive connectivity with native WQHD content support with HDMI, DisplayPort, and dual link DVI
  • Featuring SplendidPlus, VividPixel, EyeCare and QuickFit technologies for user oriented experience
  • Ergonomic tilt, swivel, pivot and height adjustment plus smart cable management
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality visuals. It allows users to view greater image detail and do more with a larger onscreen footprint. With this WQHD display, you enjoy significantly more desktop space to spread out your windows and palettes. It is also sharper than a generic Full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming. The ASUS PB277Q is undoubtedly your advanced choice for work and play.
Product Description ASUS PB277Q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class C
Energy Consumption per Year 72 kWh
Power Consumption (On mode) 49 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution QHD WQHD 2560 x 1440 at 75 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 16.7 million colours (8-bit)
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 62.5 cm x 21.8 cm x 42.8 cm
Weight 7.3 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, PSE Mark, J-MOSS, ErP Ready, TCO Displays 6.0, RCM, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PB277Q 27" 2560x1...
£277.77
