The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality visuals. It allows users to view greater image detail and do more with a larger onscreen footprint. With this WQHD display, you enjoy significantly more desktop space to spread out your windows and palettes. It is also sharper than a generic Full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming. The ASUS PB277Q is undoubtedly your advanced choice for work and play.
Product Description | ASUS PB277Q - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class C | Energy Consumption per Year | 72 kWh | Power Consumption (On mode) | 49 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | QHD WQHD 2560 x 1440 at 75 Hz | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours (8-bit) | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 62.5 cm x 21.8 cm x 42.8 cm | Weight | 7.3 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, PSE Mark, J-MOSS, ErP Ready, RCM, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | TN |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Controls & Adjustments | Input select, colour temperature |
Features | Picture in picture, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology |
Colour | Black |
Dimensions (WxDxH) | 62.5 cm x 21.8 cm x 42.8 cm - with stand |
Weight | 7.3 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (dual link) , DisplayPort , HDMI , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 120 |
Rotation Angle | 90 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 38.7 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 62.5 cm - depth: 21.8 cm - height: 42.8 cm - weight: 7.3 kg , Without stand - width: 62.5 cm - depth: 6.3 cm - height: 36.8 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 75.3 cm |
Shipping Depth | 22.4 cm |
Shipping Height | 45.2 cm |
Shipping Weight | 10.5 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
