Asus PB27UQ 27" 3840x2160 5MS HDMI Monitor
£611.11
Delivery:
Standard: 1-3 working days
Key features
  • See every detail in 27-inch 4K display with 3840 x 2160 UHD resolution, 163 pixels per inch, 100% sRGB, 10-bit color and 178-degree wide-viewing angle
  • 4K UHD content playbacks at 60Hz through DisplayPort 1.2 and HDMI (v2.0) ports
  • User-friendly design with PiP and PbP support in 4K UHD; ergonomic tilt, swivel, pivot, and height adjustments
Product codes
Open your eyes to breathtaking levels of detail with the ASUS PB27UQ 4K UHD monitor. The PB27UQ features a 16:9 aspect ratio WLED display that delivers next-generation 3840 x 2160 resolution 4K UHD visuals. With a pixel density of 163 pixels-per-inch (PPI), the PB27UQ has over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB27UQ features In-Plane Switching technology for 178-degree wide-viewing angles on both horizontal and vertical planes, as well as 100% sRGB wide color gamut for consistent color reproduction and true-to-life visuals.
ASUS PB27UQ - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Power Consumption (On mode)
60 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
3xHDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62.496 cm x 22.006 cm x 55.776 cm
7.7 kg
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, ErP Ready, E-Standby, KC, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, CEL level 0, TUV Rheinland Flicker Free Certification
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PB27UQ 27" 3840x2...
£611.11
