General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class C |
Energy Consumption per Year |
88 kWh |
Power Consumption (On mode) |
60 W |
Diagonal Size |
27" |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz) |
Pixel Pitch |
0.15525 mm |
Pixel Per Inch |
163 |
Brightness |
300 cd/m² |
Contrast Ratio |
1000:1 / 100000000:1 (dynamic) |
Colour Support |
1.07 billion colours |
Response Time |
5 ms (grey-to-grey) |
Vertical Refresh Rate |
23 - 80 Hz |
Horizontal Refresh Rate |
24 - 160 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare |
Backlight Technology |
WLED |
Features |
Picture in picture, picture by picture, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut, ASUS GamePlus, ASUS VividPixel Technology, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, 75% NTSC colour gamut, Colour Temperature Selection, 178° horizontal and vertical viewing angle, Bluelight Filter |
Colour |
Black |
Dimensions (WxDxH) |
62.496 cm x 22.006 cm x 55.776 cm - with stand |
Weight |
7.7 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Connectivity |
Interfaces |
3 x HDMI , DisplayPort , Audio line-in , Headphones |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+20 |
Swivel Angle |
120 |
Rotation Angle |
90 |
Height Adjustment |
150 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
1 x audio cable |
Compliant Standards |
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, ErP Ready, E-Standby, KC, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, CEL level 0, TUV Rheinland Flicker Free Certification |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
60 Watt |
Power Consumption (Off Mode) |
0.5 Watt |
On / Off Switch |
No |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 62.496 cm - depth: 22.006 cm - height: 55.776 cm - weight: 7.7 kg , Without stand - width: 62.496 cm - depth: 5.88 cm - height: 36.823 cm |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
