Asus PB287Q 28" 3840x2160 1ms HDMI DisplayPort LED Monitor
£379.58
Delivery:
Key features
  • Impeccable 4K ultra-high definition visuals
  • When 4K means seeing and doing much more
  • Welcoming presumes and gamers alike to the 4K UHD club
  • Everything you need, built right in
  • One display, two sources
  • ASUS-exclusive technologies for stunning image quality
  • Say hello to extraordinary comfort
  • Diagonal Size: 28in
  • Max Resolution: 3840 x 2160
  • Response Time: 1ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
Open your eyes to breathtaking levels of detail with the ASUS PB287Q True 4K ultra-high definition (4K UHD) monitor. The ASUS PB287Q features a 16:9 aspect ratio WLED display that delivers 4K UHD visuals, with resolution up to 3840 by 2160. With a pixel density of 157 pixels-per-inch (PPI), the PB287Q provides over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB287Q also delivers an impressive 1ms GTG fast response time and a 60 Hz refresh rate for ultra-smooth gameplay.
The ASUS PB287Q features extensive connectivity options that include DisplayPort 1.2 for true 4K UHD content support at refresh rates of up to 60 Hz, HDMI and a second HDMI port that supports MHL. You can also use the MHL with HDMI connection to view content from your mobile device on the PB287Q while simultaneously charging the mobile device.
Product Description ASUS PB287Q - LED monitor - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 26 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch 0.16 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 66 cm x 22.006 cm x 41.4 cm
Weight 7.9 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, ERP, CEL level 1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PB287Q 28" 3840x2...
£379.58
