Open your eyes to breathtaking levels of detail with the ASUS PB287Q True 4K ultra-high definition (4K UHD) monitor. The ASUS PB287Q features a 16:9 aspect ratio WLED display that delivers 4K UHD visuals, with resolution up to 3840 by 2160. With a pixel density of 157 pixels-per-inch (PPI), the PB287Q provides over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB287Q also delivers an impressive 1ms GTG fast response time and a 60 Hz refresh rate for ultra-smooth gameplay.
The ASUS PB287Q features extensive connectivity options that include DisplayPort 1.2 for true 4K UHD content support at refresh rates of up to 60 Hz, HDMI and a second HDMI port that supports MHL. You can also use the MHL with HDMI connection to view content from your mobile device on the PB287Q while simultaneously charging the mobile device.
Product Description | ASUS PB287Q - LED monitor - 28" | Device Type | LED-backlit LCD monitor - 28" | Energy Class | Class B | Energy Consumption per Year | 38 kWh | Power Consumption (On mode) | 26 W | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz) | Pixel Pitch | 0.16 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | 2xHDMI, DisplayPort | Speakers | Integrated | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 66 cm x 22.006 cm x 41.4 cm | Weight | 7.9 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, ERP, CEL level 1 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 28" |
Viewable Size | 28" |
Panel Type | TN |
Pixel Per Inch | 157 |
Vertical Refresh Rate | 30 - 75 Hz |
Horizontal Refresh Rate | 24 - 99 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Controls & Adjustments | Volume, brightness, contrast, input select, colour temperature |
Features | Picture in picture, picture by picture, Zero Bright Dot, HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology |
Colour | Black |
Dimensions (WxDxH) | 66 cm x 22.006 cm x 41.4 cm - with stand |
Weight | 7.9 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Clamp |
Cables Included | 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 60 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 66 cm - depth: 6.355 cm - height: 38.067 cm |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
