Asus PB328Q 32" 2560x1440 DVI VGA HDMI Monitor
£551.18
Delivery:
Standard: 1-3 working days
Key features
  • True to life picture detail & colors
  • 10-bit color for smoother gradations
  • Wide viewing angle
  • See better and wider
  • Made for work and play
  • 6-axis independent color adjustment
  • Hassle-free setting
  • Picture-in-Picture and Picture-by-Picture
  • QuickFit virtual scale function
  • Ergonomic design
  • For your comfort viewing experience
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £554.67
Save £1.50
WQHD super narrow bezel professional monitor with wide viewing angle. Ultra-wide viewing-angle eliminates color shift for excellent visual performance. Provides 100% sRGB color space with WQHD resolution. Eye care features including Flicker free, Low Blue Light, anti-glare & ergonomic adjustment stand. User-friendly design: super narrow bezel, 6-axls color adjustment, 5-way OSD navigation joystick, Quick release stand, QuickFit and SplendidPlus functions.
Product Description ASUS PB328Q - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class A
Energy Consumption per Year 52 kWh
Power Consumption (On mode) 36 W
Features 5-way joystick, USB 3.0 hub
Panel Type VA
Aspect Ratio 16:9
Native Resolution QHD WQHD 2560 x 1440
Brightness 300 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 73.5 cm x 24.2 cm x 62.5 cm
Weight 11.8 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PB328Q 32" 2560x1...
£551.18
