Asus PB60G Intel Core i5-8400T 16GB 256GB SSD 1TB Windows 10...
Asus PB60G Intel Core i5-8400T 16GB 256GB SSD 1TB Windows 10 Professional 64-bit
£989.24
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Workstation-grade performance, slim style
  • Powerful graphics
  • Versatile, space-saving design
  • Comprehensive connectivity
  • Comprehensive protection, inside and out
  • Processor Type: Core i5
  • Operating System: Windows 10 Pro
  • Installed Memory: 16GB, 16GB
  • Hard Drive Capacity: 1.256TB
  • Storage Type: SSD
Product codes
Solid reliability for your business
ASUS Mini PC PB60G is a compact workstation mini PC that features a stackable, modular design to deliver powerful customizability for professional usage. High-end NVIDIA® Quadro® P620 or Quadro® P1000 graphics combined with ISV certification makes Mini PC PB60G a perfect choice for 2D and 3D CAD applications. HDMI, DisplayPort and four mini DisplayPort outputs support up to seven displays for professionals who work with lots of visual information. ASUS Mini PC PB60G is also part of the ASUS Corporate Stable Model program, providing businesses with extensive support for long-term use and worry-free maintenance.
Powered by the 8th Gen Intel® Core™ Processors, ASUS Mini PC PB60G increases performance by up to 30% compared to previous generation processors for smoother handling of intensive computing tasks. Up to 32GB of fast DDR4 2400MHz memory boosts performance even further for improved multitasking, and a dual-storage design with one M.2 PCIe 3.0 x4 SSD and one 2.5-inch HDD provides the perfect mix of fast data transfers and high storage capacity.
Powerful NVIDIA® Quadro® graphics
ASUS Mini PC PB60G comes with a graphics module featuring an NVIDIA® Quadro® P620 or Quadro® P1000 graphics card to deliver fast, high-power performance when working with 2D or 3D models. Combined with support for up to seven 4K HDR displays that give you an expansive visual workspace to view your creations in stunning detail, Mini PC PB60G is the perfect tool for fields involving complex design tasks, such as media and entertainment, manufacturing, engineering and architecture.
Independent software vendor (ISV) certification
Independent software vendor (ISV) software is becoming an important factor to users in variety of industries. ASUS works in close partnership with ISV vendors, such as Adobe and Autodesk, to test and verify compatibility. This ensures ASUS Mini PC are reliable and highly effective for users in different fields.
High-speed data performance and large storage capacities
ASUS Mini PC PB60G supports Intel® Optane™, a smart and adaptable memory* technology that accelerates system performance and responsiveness, enabling up to 24X faster HDD access speeds, 19% faster daily computing performance, and 2.1X faster file searches. A high-capacity HDD, coupled with Intel® Optane™ memory, provides the optimal combination of large storage and incredibly fast data access.
ASUS Mini PC PB60G has a stylish metal case that measures just 17.5 x 17.5 x 7cm, so it takes up very little room to help you maintain a clutter-free workspace. It can also be mounted easily to the back of any VESA-compatible display, making it perfect for a range of business applications — from a media server to a store kiosk.
Stackable, modular design for added functionality
ASUS Mini PC PB60G features a stackable, modular design with a choice of optional components, such as optical drive, that give you customized functionality to meet your specific needs.
Product Description ASUS Mini PC PB60G B5024ZD - mini PC - Core i5 8400T 1.7 GHz - 16 GB - 1.256 TB
Type Workstation - mini PC
Processor 1 x Intel Core i5 (8th Gen) 8400T / 1.7 GHz (3 GHz) (6-core)
RAM 16 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 256 GB
Hard Drive (2nd) 1 x 1 TB - Serial ATA
Optical Storage No optical drive
Graphics Controller NVIDIA Quadro P620
Video Memory 2 GB GDDR5 SDRAM
Networking GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0
OS Provided Windows 10 Pro
Colour Black
Dimensions (WxDxH) 17.5 cm x 17.5 cm x 7.02 cm
Weight 1.59 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PB60G Intel Core...
£989.24
