Asus PCE-N10 Wireless-N150 PCI Express Adapter
£20.10
Delivery:
Key features
  • WPS (Wi-Fi Protected Setup) button - quickly set up a secure wireless connection
  • Software AP - connects your notebook and game consoles to the Internet
  • Supports WEP, WPA-PSK, and WPA2-PSK methods for enhanced security
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
Easily Turn Your Desktop Wireless
The ASUS PCE-N10 is designed to provide complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI Express connector. The PCE-N10 Wireless-N PCI Express Adapter provides wide compatibility, fitting with any standard PCI Express slot, x1, x2, x8, or x16. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet calls and video streaming.
Enhanced Security
Supports 64/128-bit WEP,WPA2-PSK,WPA-PSK,WPS security.
For quickly setting up a secure wireless connection, install the utility from the Support CD, then press the hardware WPS button on the PCE-N10 and click "next". Press the hardware WPS button on the router you would like to connect to, and that's it! After the utility finishes the setup procedure, the wireless connection is done!
Software AP Mode
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
Product Description ASUS PCE-N10 - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express
Dimensions (WxDxH) 12.1 cm x 8.8 cm x 2.2 cm
Weight 56 g
Data Link Protocol 802.11b/g/n
Data Transfer Rate 150 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
System Requirements Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PCE-N10 Wireless-...
£20.10
