Asus PRIME B350M-A AMD B350 AM4 DDR4 PCIe3.0 M.2 USB3.1 mATX
£70.27
Delivery:
Key features
  • 5X Protection III: multiple hardware safeguards for all-round protection
  • LED illumination: lighting control for both PCIe slot and audio trace paths
  • Native M.2: lightning-fast storage speeds
  • Onboard USB 3.1: fast 10Gbps transfers
  • One-stop controls: UEFI BIOS with EZ Flash 3
  • Processor Socket: Socket AM4
  • Chipset: AMD B350 FCH
  • Graphics: Graphics adapter (CPU required)
  • Form Factor: Micro ATX
  • Memory Support: DDR4 SDRAM
Product codes
AMD AM4 uATX motherboard with LED lighting, DDR4 3200MHz , 32Gb/s M.2, HDMI, SATA 6GB/s, USB 3.1
  • 5X Protection III: Multiple hardware safeguards for all-round protection
  • LED illumination: Lighting control for both PCIe slot and audio trace paths
  • Native M.2: Lightning-fast storage speeds
  • Onboard USB 3.1: Latest connectivity for ultrafast 10Gbps transfers
  • One-stop controls: Media-acclaimed UEFI BIOS with EZ Flash 3
ASUS Prime is the next evolution of the ASUS motherboard, born of a pedigree that stretches back to 1989. Our team of world-class engineers are passionate about empowering everyone to enjoy the benefits of customization and tuning, and the driving force behind the development of Prime is to make advanced enthusiast controls easily accessible — maximizing performance, stability and compatibility for the very best DIY PC experiences. Simply stated: it's time for Prime.
Built to Last
ASUS is the world's foremost motherboard manufacturer, renowned for our unique Design Thinking approach. Our exhaustive testing exceeds industry standards, supported by high-quality components for exceptional real-world protection. Our motherboards are proven to be compatible with more than 1,000 components and devices, and each new model undergoes a minimum of 8,000 hours of strict validation. ASUS gives you the peace of mind of knowing that your motherboard is fit for all environments and applications. By choosing ASUS, you also gain the freedom to select outstanding component options, for trouble-free DIY experiences.
5X Protection III
PRIME B350 series motherboards are engineered with industry-leading 5X Protection III, employing the finest components, excellent circuit design, and exacting standards to guarantee the quality and long-term durability of your motherboard. That means exceptional protection and stability for your build — thanks to decades of engineering experience from the world's leading motherboard brand.
Product Description ASUS PRIME B350M-A - motherboard - micro ATX - Socket AM4 - AMD B350 FCH
Product Type Motherboard - micro ATX
Chipset Type AMD B350 FCH
Processor Socket 1 x Socket AM4
Compatible Processors Athlon, A series, Ryzen 7 (supports 7th Generation A-series / Athlon)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 4 x SATA-600 (RAID), 2 x SATA-600, 1 x M.2
USB / FireWire Ports USB 3.0, USB 3.1 2 x USB 3.1 + 4 x USB 3.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size 2 GB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PRIME B350M-A AMD...
£70.27
