Asus PRIME H270-PRO Intel H270 S1151 DDR4 M.2 USB3.1 ATX
£89.02
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fortified PCIe slot prevents damage
  • Pumped-up throughput, 2.5x higher surge tolerance
  • World-class circuit-protecting power design
  • Electrostatic discharge protection
  • Top-to-bottom reliability
Product codes
  • Maximize your connectivity and speed with integrated Dual M.2 slots with Intel® Optane™ Memory compatibility, front panel USB 3.0 and rear USB 3.1 Type A / Type C connections.
  • 5X Protection III Hardware-level safeguards provide component longevity and reliability.
  • FanXpert 4 Core delivers advanced fan control with an integrated AIO pump header for dynamic cooling.
  • Dual Patent-pending SafeSlot Core fortified PCIe slot prevents damage caused by heavyweight GPUs.
  • On-board 3D-printing mounts for creating unique designs on your customized build.
ASUS PRIME H270-PRO - motherboard - ATX - LGA1151 Socket - H270
Motherboard - ATX
Chipset Type
Intel H270
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
USB 3.0, USB 3.1, USB-C 1 x USB-C + 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PRIME H270-PRO In...
£89.02
