Asus PRIME X370-PRO AMD X370 AM4 DDR4 M.2 USB3.1 PCIe3.0 ATX
£126.63
Delivery:
Standard: 1-3 working days
Key features
  • 5-Way Optimization: One-click system-wide tuning that now also senses GPU temperatures to ensure cooler gaming
  • ASUS Aura Sync - World's first synced RGB lighting with easy controls to orchestrate Aura Sync-capable hardware
  • Refined Audio: Realtek ALC1220 codec provides pristine and powerful audio quality
  • ASUS SafeSlot: Patent-pending PCIe with enhanced retention and shearing resistance
  • 5X Protection III: Multiple hardware safeguards to protect components from damage by power or electrical surges
  • Processor Socket: Socket AM4
  • Chipset: AMD X370
  • Graphics: Graphics adapter (CPU required)
  • Form Factor: ATX
  • Memory Support: DDR4 SDRAM
Product codes
AMD AM4 ATX motherboard with Aura Sync, DDR4 3200MHz, 32Gb/s M.2, DP/HDMI, SATA 6GB/s, USB 3.1
  • ASUS Aura Sync – World’s first synced RGB lighting with easy controls to orchestrate Aura Sync-capable hardware
ASUS Prime is the next evolution of the ASUS motherboard, born of a pedigree that stretches back to 1989. Our team of world-class engineers are passionate about empowering everyone to enjoy the benefits of customization and tuning, and the driving force behind the development of Prime is to make advanced enthusiast controls easily accessible — maximizing performance, stability and compatibility for the very best DIY PC experiences. Simply stated: it's time for Prime.
One-click Overclock and Cooling
Get performance, efficiency, digital power, fan control, networking and audio tuning - all tailored with just one click.
ASUS 5-Way Optimization makes your PC smart. It dynamically optimizes essential aspects of your system based on real-time usage — so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans, and now networking and audio settings that are tailored to your apps. In short, 5-Way ASUS Optimization ensures that your PC is perfect for gaming, entertainment and productivity!
• Games run swiftly and smoothly with high performance, prioritized bandwidth and vivid sound.
• Fans stay whisper-quiet for everyday computing, and ensure extreme cooling efficiency when gaming.
• Stutter is eliminated for smooth-running apps, even under heavy loading.
• Energy=-conserving design saves your money.
DDR4 Support
With DDR4, you'll accelerate memory frequencies up to an incredible to 3200MHz! And ASUS works with almost every DDR4 memory vendor, so you're assured the best compatibility
Media-acclaimed UEFI BIOS
The smoothest, slickest mouse-controlled graphical BIOS has been improved to make it even more appealing. Whether you're a PC novice or a seasoned overclocker, EZ and Advanced modes help you find your way, quickly and easily.
Outshine The Competition
ASUS Aura Sync technology for distinctive lighting effects
Aura Sync takes RGB lighting beyond the checkbox, combining and controlling the LEDs of your Aura-enabled products from a single application — so you can achieve perfect, synchronized lighting harmony. Aura lets you sync light effects across your graphics card, Prime X370-Pro motherboard, and an ever-growing portfolio of Aura-enabled products.
Product Description ASUS PRIME X370-PRO - motherboard - ATX - Socket AM4 - AMD X370
Product Type Motherboard - ATX
Chipset Type AMD X370
Processor Socket 1 x Socket AM4
Compatible Processors Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 8 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports USB 3.0, USB 3.1, USB-C 1 x USB-C + 2 x USB 3.1 + 5 x USB 3.0 + (1 x USB-C + 2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size 2 GB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PRIME X370-PRO AM...
£126.63
