Asus PRIME Z270-A Intel Z270 S1151 DDR4 M.2 USB3.1 ATX
£161.07
Delivery:
Standard: 1-3 working days
Key features
  • One-click overclock and cooling
  • OC design - ASUS PRO Clock technology
  • DDR4 overclocking strength in numbers
  • Native M.2/NVMe PCIe RAID support for lightning fast storage speed
  • Brighten up your build
  • SafeSlot - protect your graphics card investment
  • Processor Socket: LGA1151 Socket
  • Chipset: Intel Z270 Express
  • Graphics: Graphics adapter (CPU required)
  • Form Factor: ATX
  • Memory Support: DDR4 SDRAM
Product codes
ASUS PRIME Z270-A LGA1151 DDR4 DP HDMI DVI M.2 USB 3.1 Z270 ATX Motherboard
  • 5-Way Optimization with Auto-Tuning and FanXpert 4 automatically tailors overclocking profiles to your unique build for maximum OC performance and dynamic system cooling
  • Maximize your connectivity and speed with integrated Dual M.2, Intel® Optane™ Memory compatibility, USB 3.1 Type A / Type C connections, and Intel® Thunderbolt 3 support
  • Dual Patent-pending SafeSlots featuring an injection molding process that integrates metal framing for a stronger, firmly anchored PCIe slot built for heavyweight GPUs
  • AURA Sync RGB lighting features a nearly endless spectrum of colors with the ability to synchronize effects across an ever-expanding ecosystem of AURA Sync enabled products
  • On-board 3D-printing mounts for creating unique designs on your customized build
Product Description ASUS PRIME Z270-A - motherboard - ATX - LGA1151 Socket - Z270
Product Type Motherboard - ATX
Chipset Type Intel Z270 Express
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.0, USB 3.1, USB-C 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size 1 GB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus PRIME Z270-A Inte...
£161.07
