ROG Claymore is the world's first RGB mechanical gaming keyboard with a detachable numeric keypad to give you flexible placement options when gaming. It features Cherry MX RGB switches to give you precise and responsive keystrokes and individually-programmable backlit keys with Aura sync RGB LED technology for unmatched levels of personalization. This 100% anti-ghosting keyboard has N-Key rollover technology, on the fly macro recording, and dedicated hotkeys for exclusive ASUS motherboard cooling and overclocking controls. ROG Claymore gives you the winning edge in the digital battlefield.
Product Description | ASUS ROG Claymore - keyboard - UK - black | Device Type | Keyboard | Backlit | RGB | Interface | USB | Layout | UK | Hot Keys Function | Volume, mute | Numeric Keypad | Yes | Key Switch Type | CHERRY MX Red | Colour | Black | Dimensions (WxDxH) | 45 cm x 14.5 cm x 4.5 cm | Weight | 943 g | Manufacturer Warranty | 2-year warranty |
General | |
Backlit | RGB |
Interface | USB |
Input Device | |
Layout | UK |
Keyboard Technology | Mechanical |
Adjustable Height | Yes |
Detachable Cable | Yes |
Features | Numeric keypad |
Width | 45 cm |
Depth | 14.5 cm |
Height | 4.5 cm |
Weight | 943 g |
Miscellaneous | |
Colour | Black |
Cable Length | 1.8 m |
Included Accessories | 2 x ROG pouches |
Software & System Requirements | |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
