Asus ROG Claymore Keyboard (100%) Red Switch
Key features
  • Individually-backlit keys with Aura Sync RGB LED technology for unlimited personalization options
  • Fully programmable keys with on the fly macro recording
  • 100% anti-ghosting with N-key rollover (NKRO) technology
  • Hotkeys for fan speed, lighting and overclocking controls when paired with an ASUS ROG motherboard
  • Onboard memory to save profiles on the go and intuitive ROG Armory for lighting, key, and stats settings
  • Durable aluminum construction with intricate Mayan-inspired detailing
Product codes
ROG Claymore is the world's first RGB mechanical gaming keyboard with a detachable numeric keypad to give you flexible placement options when gaming. It features Cherry MX RGB switches to give you precise and responsive keystrokes and individually-programmable backlit keys with Aura sync RGB LED technology for unmatched levels of personalization. This 100% anti-ghosting keyboard has N-Key rollover technology, on the fly macro recording, and dedicated hotkeys for exclusive ASUS motherboard cooling and overclocking controls. ROG Claymore gives you the winning edge in the digital battlefield.
Product Description ASUS ROG Claymore - keyboard - UK - black
Device Type Keyboard
Backlit RGB
Interface USB
Connectivity Technology Wired
Localization and Layout UK
Hot Keys Function Volume, mute
Numeric Keypad Yes
Key Switch Type CHERRY MX Red
Colour Black
Dimensions (WxDxH) 45 cm x 14.5 cm x 4.5 cm
Weight 943 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
