Asus ROG Pugio Mouse
£82.23
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Configurable side buttons
  • Exclusive push-fit switch socket design
  • Dominating aesthetics
  • Durable switches
  • Advanced optical sensor
  • Separate button design
Product codes
ROG Pugio is an ambidextrous gaming mouse that offers ultimate customizability to meet the needs of hardcore gamers. Its configurable side buttons let you decide on your own side button layout, while exclusive push-fit switch sockets offer variable click resistance. The push-fit design makes it easy to replace worn out switches to extend the lifespan of the mouse. The Pugio features stunning, aggressive aesthetics to match its performance - including angular ASUS Aura RGB light channels with Aura Sync support.
Product Description ASUS ROG Pugio - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Dimensions (WxDxH) 6.8 cm x 12 cm x 3.7 cm
Weight 103 g
Movement Detection Technology Optical
Buttons Qty 7
Movement Resolution 7200 dpi
Performance 30 G maximum acceleration, 150 inches per second
Features OMRON switches, separate right/left buttons, ASUS Aura Sync RGB LED
OS Required Microsoft Windows 7 / 8.1 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£82.23
