FIGHT TILL DAYLIGHT
Aim for esports excellence with the ROG Strix SCAR III, engineered to compete at the top tier of Windows 10 Pro gaming. Intelligent Cooling unleashes the raw power of the 9th Gen Intel Core CPU and GeForce RTX™ graphics, while the world’s fastest 240Hz/3ms laptop display lets you play at the speed of pro gaming. Jump into multiplayer matches anywhere with stronger RangeBoost Wi-Fi, show off your personality with the wraparound Aura Sync light bar, and gain privacy for personal data with the new ROG Keystone.
FORWARD-THINKING FUNCTIONAL DESIGN
Efficiency and innovation unite in the sleek, gunmetal grey ROG Strix SCAR III. Its strategic design is inspired by our collaboration with BMW Designworks Group, and carves out a cooling advantage with its 3D Flow Zone. The subtle, carbon-patterned interior is accented by Aura Sync lighting that extends across the new wraparound light bar, keyboard, and ROG logo. Whether you’re gearing up for competition or hopping into quickplay, this metal-capped machine is fine-tuned and ready for action.
INTRODUCING THE KEYSTONE
Keystones offer a versatile new way to personalize your machine and protect your personal data. These physical, NFC-enabled keys fit neatly into the Strix SCAR III’s chassis, adding a subtle accent along the trim. When docked, they instantly transform your machine with different effects and game-specific profiles, or unlock access to a secret Shadow Drive for covert private storage. This is only the beginning of the Keystone’s potential. Glimpse the future today.
SEE THE GAME AT PROFESSIONAL SPEED
Play at the speed of professional esports with the world’s fastest gaming laptop display. The 240Hz/3ms panel enables true high-FPS gameplay capable of keeping up with competitive gaming at the highest level. Stay in the flow of fast-paced action with impeccably smooth, crisp visuals that heighten your immersion. Get an edge in combat where rapid response and environmental awareness are crucial to victory. Experience games the way the pros do, and take your skills to the next level.
Product Description | ASUS ROG Strix SCAR III G731GV EV025T - 17.3" - Core i7 9750H - 16 GB RAM - 512 GB SSD + 1 TB Hybrid Drive | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i7 (9th Gen) 9750H / 2.6 GHz (4.5 GHz) | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 512 GB SSD NVMe + 1 TB Hybrid Drive / 5400 rpm | Optical Drive | No optical drive | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA GeForce RTX 2060 / Intel UHD Graphics 630 | Video Memory | 6 GB GDDR6 SDRAM | Keyboard Backlight | Yes (RGB) | Networking | 802.11ac, Bluetooth 5.0, Gigabit Ethernet | Battery | 4-cell | Colour | Black | Dimensions (WxDxH) | 39.9 cm x 29.3 cm x 2.62 cm | Weight | 2.85 kg |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (9th Gen) 9750H / 2.6 GHz |
Max Turbo Speed | 4.5 GHz |
Number of Cores | 6-core |
64-bit Computing | Yes |
Chipset | Mobile Intel HM370 |
Features | Intel Turbo Boost Technology |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD - (M.2) PCIe - NVM Express (NVMe) |
Secondary Storage | 1 TB Hybrid Drive SATA / 5400 rpm - Seagate |
Display | |
Type | 17.3" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Anti-glare, 72% NTSC colour gamut, 100% sRGB colour gamut, 3 ms response rate, 144 Hz refresh rate, 75.35% Adobe RGB colour gamut, 170° viewing angle |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA GeForce RTX 2060 / Intel UHD Graphics 630 |
Video System Features | NVIDIA Optimus |
Sound | Stereo speakers, array microphone |
Input | |
Type | Keyboard, touchpad |
Features | Chiclet keyboard, per-key RGB, keystone button |
Communications | |
Wireless | 802.11ac, Bluetooth 5.0 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 66 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 230 Watt, 19.5 V, 11.8 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , USB-C 3.1 Gen 2/DisplayPort 1.4 , 3 x USB 3.1 , HDMI , LAN |
Miscellaneous | |
Colour | Black |
Case Material | Polycarbonate ABS, plastic |
Features | System password |
Included Accessories | 1080P webcam, power adapter, palm rest label |
Dimensions & Weight | |
Weight | 2.85 kg |
