Asus ROG SWIFT Curved PG348Q 34" UWQHD (3440x1440) Gamin...
£1,076.38
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Amazing design
  • Stunning visuals
  • Panoramic gaming arena
  • Seamless gameplay
  • NVIDIA G-SYNC technology
  • GamePlus technology
  • Frameless edge-to-edge design
  • Robust connectivity
  • Flicker-Free technology
  • Ergonomic design
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI
Product codes
The Swift PG348Q expands your scope, allowing faster target acquisition while increasing immersive visuals with a 34-inch curved ultra-wide IPS panel. Bristling with advanced display tech, the Swift PG348Q also features NVIDIA G-SYNC technology for smooth and seamless gameplay, while simultaneously sporting a great refresh rate, eliminating roadblocks between your skill and victory. Add the armored design and amazing ASUS features and you're looking at a monitor that is truly unrivaled.
Product Description ASUS ROG SWIFT PG348Q - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class B
Energy Consumption per Year 77 kWh
Power Consumption (On mode) 53 W
Curved Screen Yes
Adaptive-Sync Technology NVIDIA G-SYNC
Features 5-way joystick, USB 3.0 hub
Panel Type IPS
Aspect Ratio 21:9
Native Resolution 3440 x 1440 at 100 Hz
Pixel Pitch 0.2325 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare
Colour Armor titanium, plasma cooper
Dimensions (WxDxH) - with stand 82.9 cm x 29.7 cm x 55.8 cm
Weight 11.2 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus ROG SWIFT Curved...
£1,076.38
