Asus ROG ZENITH EXTREME AMD X399 STR4 DDR4 PCIe3.0 M.2 U.2 eATX
£522.99
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • MD Ryzen Threadripper processor series: ready for the latest SocketTR4 CPUs
  • Onboard M.2 Heatsink: cools your M.2 drive, delivering consistent storage performance and enhanced reliability
  • Synchronize RGB lighting: with a vast portfolio of Aura Sync capable PC gear - with support for addressable light strips
  • ROG DIMM.2: dual M.2 expansion card allows use of fans to prevent throttling
  • LiveDash OLED: customizable panel displays vital system stats or your own logo
  • Best gaming networking: Intel Gigabit Ethernet, 802.11ad Wi-Fi, LANGuard and GameFirst technologies
  • Gaming audio: SupremeFX S1220 teamed with Sonic Studio III, cast an aural landscape that draws you deeper into the action.
  • 5-way optimization: automated system-wide tuning, providing overclocking and cooling profiles that are tailor made for your rig
  • Best gaming protection: SafeSlot, and carefully-selected premium components for maximum durability
  • Processor Socket: Socket TR4
  • Chipset: AMD X399
  • Graphics: None
  • Form Factor: Extended ATX
  • Memory Support: DDR4 SDRAM
Product codes
Customize your own favorite LED effects with Aura, the intuitive lighting-control software, to cast a stunning multi-color glow across your build via the ROG Zenith Extreme's brilliant built-in RGB LEDs or attached RGB strips via the two onboard 4-pin headers - all lights will perform in perfect synchronization. Fire up Aura and enjoy the creative freedom of nine different lighting schemes!
ROG Zenith Extreme includes a dedicated addressable RGB header that connects to compatible lighting strips, fans, coolers, and compatible PC cases - all to create a new world of illumination possibilities. Aura software offers an array of effects for addressable gear, and the Aura SDK takes things to the next level - allowing developers to control each LED individually, unleashing infinite lighting possibilities!
ROG Zenith Extreme comes equipped with all-new LiveDash - a built-in OLED panel that displays useful information and customizable graphics. During the power-on, self-test (POST) phase, LiveDash shows key progress stats, in simple language and via traditional POST codes. Then, during normal operation, the vibrant panel shows a choice of CPU frequency, device temperatures, fan speeds or information from the Water Cooling Zone, You're also able to customize the default LiveDash GIF, so it'll display your own image or animation.
Product Description ASUS ROG ZENITH EXTREME - motherboard - extended ATX - Socket TR4 - AMD X399
Product Type Motherboard - extended ATX
Chipset Type AMD X399
Processor Socket 1 x Socket TR4
Compatible Processors Ryzen ThreadRipper
Max RAM Size 128 GB
RAM Supported 8 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports 6 x SATA-600 (RAID), 3 x M.2, 1 x U.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 8 x USB 3.1 Gen 1 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Bluetooth, 10 Gigabit Ethernet, Gigabit Ethernet, 802.11a/b/g/n/ac, WiGig
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus ROG ZENITH EXTREM...
£522.99
