The ROG Zephyrus G deftly balances exceptional portability with potent performance to bring ultra-slim gaming laptop to a bigger audience. Its AMD Ryzen 7 processor and GeForce GTX 1660 Ti graphics power through work and play, while long-lasting battery keeps you running on the road. Immerse yourself in up to a 120Hz display framed by super-narrow bezels that practically melt away, and turn up the volume with smart amp technology that gets louder with less distortion.
Product Description | ASUS ROG Zephyrus G GA502DU-AL025T - 15.6" - Ryzen 7 3750H - 16 GB RAM - 512 GB SSD | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | AMD Ryzen 7 3750H / 2.3 GHz (4 GHz) / 6 MB Cache | Memory | 16 GB DDR4 (1 x 8 GB + 8 GB (soldered)) | Storage | 512 GB SSD NVMe | Optical Drive | No optical drive | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA GeForce GTX 1660 Ti | Video Memory | 6 GB GDDR6 SDRAM | Keyboard Backlight | Yes | Networking | Bluetooth, 802.11ac, Gigabit Ethernet | Battery | 4-cell | Colour | Black | Dimensions (WxDxH) | 36 cm x 25.2 cm x 2.04 cm | Weight | 2.2 kg |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | AMD Ryzen 7 3750H / 2.3 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Memory | |
RAM | 16 GB (1 x 8 GB + 8 GB (soldered)) |
Max RAM Supported | 24 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD - (M.2) PCIe - NVM Express (NVMe) |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare, 45% NTSC colour gamut, 120 Hz refresh rate, 62.5% sRGB colour gamut, 170° viewing angle, 47.1% Adobe RGB colour gamut |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA GeForce GTX 1660 Ti |
Sound | Stereo speakers, array microphone |
Audio Features | Smart Amplification technology |
Input | |
Type | Keyboard, touchpad |
Features | Chiclet keyboard |
Communications | |
Wireless | Bluetooth, 802.11ac |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 76 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 180 Watt, 20 V, 9 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , 3 x USB 3.1 Gen 1 , USB-C 3.1 Gen 2/DisplayPort 1.4 , LAN , HDMI |
Miscellaneous | |
Colour | Black |
Case Material | Plastic, metal |
Features | System password, Max-Q Design |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2.2 kg |
