Powered by 5th generation Wi-Fi, the 802.11ac chipset gives the RT-AC51U faster wireless speeds than N technology. At 2.4 GHz, it reaches 300 Mbps, while on the 5 GHz band it blazes to 433 Mbps. The upgraded bandwidth has the higher capacity you need to increase Wi-Fi enjoyment at home. With notebooks, desktops, pads, and smartphones now all Wi-Fi-reliant, it's time to upgrade to the next generation to expand you connectivity now and in the future.
Product Description | ASUS RT-AC51U - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 733 Mbps | Capacity | Guest networks: 6 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, LPR/LPD, FTP | Remote Management Protocol | HTTP | Features | Network monitoring, firewall protection, VPN support, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, download client, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, Samba support, FTP server, Multiple SSID support, static IP mode, ASUS AiDisk, reset button, bandwidth control, 3G/4G USB Dongle Support, dynamic IP mode, Traffic Control, Multicast Proxy support, VPN Server, ASUS AiCloud, ASUSWRT, Guest Zone support, L2TP passthrough | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 18.9 cm x 12.9 cm x 3.6 cm | Weight | 270 g | System Requirements | Linux, Microsoft Windows 2000, Apple MacOS X, Apple MacOS X 10.1, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Android, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8 | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | MPPE, 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise |
Status Indicators | Power, WAN, LAN, wireless, USB |
Expansion / Connectivity | |
Interfaces | WAN: 1 x Ethernet 10/100 - RJ-45 , LAN: 4 x Ethernet 10/100 - RJ-45 , USB 2.0: 1 x 4 pin USB Type A |
Aerial | |
Aerial | External integrated and internal |
Antenna Qty | 3 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows 2000, Apple MacOS X, Apple MacOS X 10.1, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Android, Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8 |
Dimensions & Weight | |
Width | 18.9 cm |
Depth | 12.9 cm |
Height | 3.6 cm |
Weight | 270 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
