Asus S1 Portable Pocket WXGA Projector Silver
£305.79
Delivery:
Key features
  • High capacity power bank
  • Large, bright, and clear projections on-the-go
  • Save your money and time
  • Seamless connectivity and true-to-life sound
  • Premium and durable design
  • Portability: Pocket
Product codes
The S1 mobile LED projector is designed for your on-the-go life. At just 3 cm (1.18 inches) tall and lightweight, the S1 mobile LED projector is the perfect portable projector for mobile professionals that need to travel light, so you can take it with you wherever you go. Its built-in rechargeable 22 Wh battery gives you long hour of cable-free projection time; it means you're free to set up the projector wherever you want without having to worry where the nearest power socket is.
Product Description ASUS S1 - DLP projector - ultra short-throw
Device Type DLP projector
Colour Silver
Brightness 200 lumens
Contrast Ratio 1000:1
Resolution WVGA (854 x 480)
Native Aspect Ratio 16:9
Colour Support 16.7 million colours
Lens Ultra short-throw fixed lens
Bulb type RGB LED array
Bulb life cycle Up to 30000 hour(s)
Video Input (NTSC, SECAM, PAL)
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power Consumption Operational 32 Watt
Dimensions (WxDxH) 11.05 cm x 10.2 cm x 3.07 cm
Weight 342 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus S1 Portable Pocke...
£305.79
