Strix Soar is a gaming sound card built with high-performance components to satisfy gamers who demand pure, full-sounding audio. Strix Soar features rich, immersive, and clear sound with an incredible signal-to-noise ratio (SNR), and the headphone amplifier for deep, tight bass. The simple yet powerful Sonic Studio sound utility provides complete sound card control and allows easy in-game audio adjustments.
Product Description | ASUS Strix Soar - sound card | Device Type | Sound card | Enclosure Type | Internal | Interface Type | PCI Express | Dimensions (WxDxH) | 2.2 cm x 19 cm x 13 cm | Weight | 480 g | Signal Processor | CM6632AX | Sound Output Mode | 7.1 channel surround | DAC Resolution | 24-bit | Sample Rate | 44.1 kHz (min) - 192 kHz (max) | Signal-To-Noise Ratio | 116 dB | System Requirements | Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
General | |
Form Factor | Internal |
Width | 2.2 cm |
Depth | 19 cm |
Height | 13 cm |
Weight | 480 g |
Processor / Memory | |
Audio Output | |
Frequency Response | 10 - 48000 Hz |
Features | Headphone Amplifier, Hyper Grounding Technology, Sonic Radar Pro |
Compliant Standards | ASIO 2.0 |
Audio Modes | Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz |
Expansion / Connectivity | |
Interfaces | 1 x headphones - mini-phone 3.5 mm , 1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (side)/SPDIF output - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x audio line-in/microphone - mini-phone 3.5 mm |
Miscellaneous | |
Cables Included | 1 x S/PDIF optical adapter |
Software / System Requirements | |
Software | Sonic Studio |
OS Required | Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
