Asus Supreme Bundle (Includes X99-S, Intel Core i7-5820K, 16G...
Asus Supreme Bundle (Includes X99-S, Intel Core i7-5820K, 16GB DDR4 Vengeance LPX Memory)
SUPREME PERFORMANCE SELF-BUILD! HASWELL-E CORE I7, X99 & DDR4!
Key features
  • Make your memory go faster
  • Get performance, efficiency, digital power, fan control and even networking and audio tuning tailored for you
  • Fan Xpert 3
  • Media-acclaimed UEFI BIOS
  • Evolve your storage speed with
  • Speed up with onboard M.2 up to 32Gb/s
  • App specific optimization for professionals and gamers - turbo App
  • Flawless audio that makes you part of the game
  • A double win for gaming
  • Turbo LAN
  • Multi-GPU support
  • Intel Core i7 Processor LGA2011-v3 Ready
  • Intel X99 Express Chipset
Product codes
Exclusive Self-Build Special Bundle
Perfect Supreme Gaming & Performance PC on the X99 Platform - with Intel Haswell-E Core i7 CPU Unlocked Processor!
Take the fear out of Self-Build with this tested Intel Supreme Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus X99-S Intel Motherboard: Fully loaded with unmatched performance, flawless Crystal Sound 2 audio and customizable Turbo App for your awesome X99 build.
  • Patent Pending OC Socket Drive CPU and DDR4 performance beyond all expectations!
  • 5-Way Optimization by Dual Intelligent Processors 5 - One click overclock and cooling, done!
  • 32Gb/s ultrafast M.2 x4
  • Crystal Sound 2 - Flawless audio that makes you part of the game!
  • ASUS HomeCloud - Access your PC remotely and stream multimedia content anywhere, anytime
Designed to break performance barriers, ASUS OC Socket utilizes extra pins to connect a proprietary circuit to contacts found on Haswell-E's land grid array (LGA). Combined with our customized UEFI, this exclusive feature enables higher DDR4 memory frequencies, lower latencies and enhanced stability while overclocking, extending all the way to extreme overclocking conditions, such as Liquid Nitrogen (LN2). OC Socket is 100% compatible with new Haswell-E LGA 2011-v3 CPUs, ensuring the ideal combination of overclocking performance and compatibility.
This is the first platform to support DDR4 memory and it's able to drive memory frequencies to 3200MHz (and beyond when overclocked)! ASUS-exclusive T-Topology circuit design plus OC Socket provides superb memory-overclocking capability to unleash the full power of DDR4 by minimizing coupling noise and signal reflection. With innovative equidistant memory channels, it delivers the most balanced control and powerful overclocking compatibility. ASUS works with almost every DDR4 memory vendor to ensure the best compatibility.
One click takes care of all that complex tuning. Your PC is smart with ASUS 5-Way Optimization. It dynamically optimizes essential aspects of your system based on real-time use - so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans and now even networking and audio settings that are tailored for the apps that you are using. In short, 5-Way Optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else!
Intel® Core™ i7 Processor LGA2011-v3 Ready
This motherboard supports Intel® Core™ i7 processors in the LGA2011-v3 package, with memory and PCI Express controllers integrated to support 4-channel (8 DIMM) DDR4 memory and 40/28 PCI Express 3.0/2.0 lanes.
Intel® X99 Express Chipset
The Intel® X99 Express Chipset is a single-chipset design that supports socket LGA2011-v3 Intel® Core™ i7 processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, X99 provides a maximum 6 USB 3.0 ports, 10 SATA 6Gbit/s ports for faster data retrieval.
Intel Core i7-5820K 3.30GHz SKT2011-V3 15MB Haswell-E Unlocked (BX80648I75820K)
Achieve champion status with the new 6 core Desktop Processor Intel Core i7 processor Extreme Edition. Unlocked, unleashed and uncompromised - the ultimate weapon for unrivaled performance. Massive multi-Threading and highest graphics performance and more overclocking options give you superiority over the competition.
6 independent cores of unbelievable power that encourage you to become the digital content creator or gamer you always wanted to be. Need cores to render? Check. Need cores to compile? Check. Need core to seek and destroy in the latest game? Check. It seems almost unfair to add Intel® Hyper Threading Technology for a total of 12 threads at your disposal. You want burst speed performance for those jobs that require a bit more frequency? Intel® Turbo Boost Technology has that covered. But that little voice inside of you is saying you want even more? Let that voice know that the processor is unlocked and is ready for you to tune it to fit your demanding needs. Tune cores, power, memory, or whatever else you need to tune to make your system fit your needs.
  • Fully Unlocked Processor
  • Massive Multi-Thread Performance
  • Halo Platform for Gaming, Overclocking and Content Creation
  • 1st Intel Desktop CPU with DDR4 Support
  • 22nm Haswell Microarchitecture
  • Intel® Turbo Boost Technology 2.0
  • Intel ® Hyper-Threading Technology
Corsair 16GB (4 x 4GB) Vengeance LPX 2666MHz DDR4 CL16 240-pin Memory (CMK16GX4M4A2666C16)
Designed for high-performance overclocking on Intel X99 motherboards. Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There's XMP 2.0 support for trouble-free automatic overclocking. And, they're available in multiple colors to match your motherboard, your components, or just your style.
  • Density: 16GB (4x4GB)
  • Speed: 2666MHz
  • Tested Latency: 16-18-18-35
  • Voltage: 1.2V
  • Format: Unbuffered DIMM
  • Pin Out: 288 Pin
  • Intel XMP 2.0
  • Heatspreader: Anodized Aluminum
Product Description ASUS X99-S - motherboard - ATX - LGA2011-v3 Socket - X99
Product Type Motherboard - ATX
Chipset Type Intel X99 Express
Processor Socket 1 x LGA2011-v3 Socket
Compatible Processors Core i7
Max RAM Size 64 GB
RAM Supported 8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
USB / FireWire Ports USB 3.0 8 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus Supreme Bundle (I...
