RT-AC3200 is a tri-band 802.11ac router featuring Tri-Band Smart Connect, an incredible feature that automatically maximizes the performance of each and every wireless device. With the fast combined data rate of 3200 Mbps (2600 Mbps on the two 5 GHz bands plus 600 Mbps on the 2.4 GHz band), RT-AC3200 allows every device to work at full speed, ensuring lag-free online gaming, silky-smooth 4K/UHD video streams, and effortless downloading. Add to this superb coverage and total security, and you'll see why RT-AC3200 takes your network to the next level!
Product Description | ASUS RT-AC3200 - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Data Transfer Rate | 3200 Mbps | Capacity | Guest networks: 9 | Network / Transport Protocol | PPTP, L2TP, NTP, IPSec, PPPoE, FTP, DHCP, DDNS | Routing Protocol | IGMPv2, IGMP, static IP routing, IGMPv3 | Remote Management Protocol | SNMP, HTTP | Features | Network monitoring, firewall protection, DMZ port, DHCP support, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, print server, IPv6 support, URL filtering, parental control, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), dual WAN connection, virtual server support, RADIUS support, Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Samba support, FTP server, Multiple SSID support, static IP mode, DNS proxy, ASUS AiDisk, UPnP Media Server, wireless bridge mode, reset button, IPv4 support, Apple Time Machine compatible, port triggering, 3G/4G USB Dongle Support, dynamic IP mode, ASUS AiRadar, VPN Server, ASUSWRT, Broadcom TurboQAM technology, SNMP support, VoIP support, PPTP passthrough, L2TP passthrough, ASUS AiCloud 2.0, ASUS AiProtection, Tri-Band Smart Connect technology | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac | Power | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 29 cm x 18.8 cm x 5.8 cm | Weight | 1.02 kg | System Requirements | Linux, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows XP, Apple MacOS X 10.1, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Windows 8, Apple MacOS X 10.8, Windows 8.1 | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | MPPE, 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise |
Wi-Fi AC Rating | AC3200 |
Status Indicators | Power, WAN, LAN, wireless, WPS |
Expansion / Connectivity | |
Interfaces | WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A |
Aerial | |
Antenna Qty | 6 |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Enclosure Colour | Black |
Cables Included | 1 x network cable |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Linux, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows XP, Apple MacOS X 10.1, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Windows 8, Apple MacOS X 10.8, Windows 8.1 |
Dimensions & Weight | |
Width | 29 cm |
Depth | 18.8 cm |
Height | 5.8 cm |
Weight | 1.02 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
