Asus USB-AC55 Dual-band Wireless-AC1300 USB 3.0 Wi-Fi Adapter
£61.47
Delivery:
Key features
  • Maximum flexibility for maximum wireless coverage
  • Next-generation 802.11ac wireless, up to 3x faster than 2 x 2 wireless N adapters
  • Next-generation Wi-Fi on both bands
  • USB 3.0 for full 802.11ac performance
Product codes
The ASUS USB-AC55 is a dual-band 802.11ac Wi-Fi adapter with a USB 3.0 connection that brings high-performance wireless networking support to desktop and notebook PCs. The USB-AC55 features a USB 3.0 connection with support for wireless data rates up to 400 Mbps at 2.4 GHz and 867 Mbps at 5 GHz with compatible routers. Suitable for use with both desktop and notebook PCs, the USB-AC55 features a dual internal antenna design for great wireless network coverage with minimal desktop clutter.
Next gen 802.11ac wireless, up to 3X faster than 2x2 wireless N adapters
The fastest Wi-Fi ever becomes more accessible via USB, going up to 867 Mbps on the clear 5 GHz band. Using 802.11ac wireless, faster connectivity and enjoyment come to all your devices. Compared with current 802.11n, the USB-AC55 delivers up to 867 Mbps at 5 GHz, which is 3X faster than 2x2 802.11n.
256QAM technology integrated on the USB-AC55 brings the speed benefits of next-generation 802.11ac Wi-Fi to both 2.4 GHz and 5 GHz bands. At 400 Mbps and 867 Mbps respectively, they turn the USB-AC55 into a formidable AC1300 wireless adapter. Connect the USB-AC55 to ASUS networks to attain the very highest possible Wi-Fi speeds.
USB 3.0 allows the USB-AC55 to pair with notebooks and desktops using a bandwidth up to ten times that of USB 2.0. It means the full advantage of 802.11ac networking is realized, as the adapter has enough throughput overhead to support much faster network speeds.
The USB-AC55 also includes a desktop cradle with a three-foot cable for more flexible positioning in troublesome Wi-Fi reception areas.
Product Description ASUS USB-AC55 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type SuperSpeed USB 3.0
Dimensions (WxDxH) 9.6 cm x 2.78 cm x 1.08 cm
Weight 20 g
Data Link Protocol 802.11ac
Data Transfer Rate 1267 Mbps
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
System Requirements Microsoft Windows 7, Windows 8, Windows 8.1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus USB-AC55 Dual-ban...
£61.47
