Asus USB-BT400 USB Bluetooth V4.0 Adapter
£16.41
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Most advanced Bluetooth 4.0 adapter, backward compatible with Bluetooth 2.0/2.1/3.0
  • Enables wireless communication with Bluetooth-enabled computers, printers, phones, headsets, speakers, keyboards, controllers, and more
  • Bluetooth Low Energy technology for energy-saving wireless connectivity
  • Highly portable ultra-small design
  • Wired / Wireless: Wireless
  • Protocol: Bluetooth 4.0
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
New generation Bluetooth 4.0 for versatile wireless connectivity
The USB-BT400 is a Bluetooth Smart Ready USB adapter with new Bluetooth 4.0 capabilities. It connects you with a multitude of compatible devices and supports Bluetooth Low Energy (BLE) to reduce power consumption. In dual-mode, the USB-BT400 maintains full backward compatibility with Bluetooth 3.0, 2.1, and 2.0.
Get Bluetooth 4.0 and connect with multiple devices
The ASUS USB-BT400 provides new and advanced Bluetooth 4.0 and enables wireless connectivity with a wide range of devices such as computers, printers, phones, headsets, speakers, keyboards, controllers, and more. In addition, the ultra-small USB-BT400 comes with Bluetooth Low Energy (BLE) technology, which lets you enjoy energy-saving connectivity.
The most advanced Bluetooth 4.0 adapter, backward compatible with Bluetooth 2.0/2.1/3.0
Compatible with
Windows® 8 , 32bit/64bit
Windows® 7 , 32bit/64bit
Windows® XP , 32bit/64bit
Product Description ASUS USB-BT400 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 1.947 cm x 1.6 cm x 0.81 cm
Weight 2.2 g
Data Link Protocol Bluetooth 4.0
Data Transfer Rate 3 Mbps
Frequency Band 2.4 GHz
Compliant Standards Bluetooth 4.0
System Requirements Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus USB-BT400 USB Blu...
£16.41
