Asus USB-N10 Wireless-N150 USB Nano Adapter
£13.63
Delivery:
Key features
  • 25% wider signal coverage for enhanced wireless connectivity
  • Software AP function for securely sharing an Internet connection wirelessly
  • Auto-off function to save power on the go
Product codes
The USB-N10 is specially-designed to be compact and durable to safely and securely stay plugged into a notebook PC even inside a slim carrying case. The ASUS USB-N10 NANO provides a better wireless performance for your PC than legacy wireless 802.11g technology. It uses best-in-class antenna, MIFA, to perform consistent HD quality data streaming and to extend wireless receiving range. Not only does 802.11n offer you sufficient bandwidth and range, it's also backwards compatible with 11g and 11b networks.
Product Description ASUS USB-N10 NANO - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 1.49 cm x 1.74 cm x 0.71 cm
Weight 2 g
Data Link Protocol 802.11b/g/n
Data Transfer Rate 150 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
System Requirements Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus USB-N10 Wireless-...
£13.63
