Asus USB-N13 300Mbps 802.11n USB Wireless Adapter, consistent...
Asus USB-N13 300Mbps 802.11n USB Wireless Adapter, consistent transmission and wide coverage
£21.00
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 300Mbps Pro N - secure and excellent connection
  • PSP Xlink Kai support
  • Software AP 2-in-1 device for wireless connection sharing
  • EZ WPS Wi-Fi setup - simply insert, simply connect
  • Support Multiple OS - Windows, Mac and Linux
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Form Factor: External
  • Compatibility: Mac, PC
  • Type: Network adapter
Product codes
The ASUS USB-N13's specially-designed internal antenna provides you consistent transmission and wide coverage. The WPA/WPA2 enterprise encryption enables you to access corporate certificate-based authentication network, ensure that you to communicate under fast and high protected environment.
Xlink Kai is a free software that enables PSP gamers to play system-link games via the Internet instead of via the local area network (LAN). You just enable "PSP Xlink Mode" on ASUS utility, and then wirelessly game with faraway players through Xlink server.
When you are in business trip, when you like to share your internet access, the USB-N13 build-in software AP enables you to create a small WLAN environment and connect to the internet via ICS (Internet Connection Sharing). Its ACL (Access Control List) and ICS (Internet Connection Sharing) let you easily manage your access authority and quickly turns your PC into a Wireless AP, flexible and convenient.
Simply insert USB-N13 into your computer's USB port and press the WPS button on both the router and USB-N13. Within two steps, a secure and protected wireless connection setting done!
The USB-N13 supports you multiple OS driver to easily go freedom wireless on most aboveground OS.
Product Description ASUS USB-N13 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Data Link Protocol 802.11b/g/n
Data Transfer Rate 300 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
System Requirements Linux, Microsoft Windows 2000, Apple MacOS X 10.3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus USB-N13 300Mbps 8...
£21.00
