Asus USB-N14 Wireless USB Adapter 802.11n 300 Mbps
£28.24
Delivery:
Key features
  • Dual detachable 5 dBi high-gain antenna supports up to 10x signal coverage
  • Bundled USB extension cable for flexible placement to pinpoint best reception
  • EZ WPS - Wi-Fi configuration setting in just 2 steps with WPS hardware push button
Product codes
Get more flexibility when placing the USB-N14 adapter with the bundled USB extension cable. Greater freedom of placement means better reception, as it allows you to fine-tune positioning for the best signal available.
With the detachable high-gain antenna you get the option to greatly increase your signal coverage up to 10x more extensive than wireless-g adapters. Detachable design means you can connect and disconnect antennas at will, and even upgrade them in future if needed.
Product Description ASUS USB-N14 - network adapter - USB 2.0
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 5.5 cm x 9 cm x 1.1 cm
Data Link Protocol 802.11b/g/n
Data Transfer Rate 300 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
System Requirements Microsoft Windows XP, Microsoft Windows 7, Linux Kernel 2.6, Apple MacOS X Lion 10.7, Windows 8, Apple MacOS X 10.8, Apple MacOS X 10.9
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus USB-N14 Wireless...
£28.24
